Penta-Power Sequence Controller with Hot swap and System Management The X80010, X80011, X80012, X80013 contain three major functions: a power sequencing controller, a hotswap controller, and systems management support. The power sequencer controller time sequences up to five DC/DC modules. The device allows various DC/DC power sequencing configurations, either parallel or relay modes. The power good, enable, and voltage good signals provide for flexible DC/DC timing configurations. Each voltage enable signal has a built-in delay while additional delay can be added with simple external passive components. The hot swap controller allows a board to be safely inserted and removed from a live backplane without turning off the main power supply. The X80010 family of devices offers a modular, power distribution approach by providing flexibility to solve the hotswap and power sequencing issues for insertion, operations, and extraction. Hardshort Detection and Retry with Delay, Noise filtering, Insertion Overcurrent Bypass, and Gate Current selection are some of the integrated features of the device. During insertion, the gate of an external power MOSFET is clamped low to suppress contact bounce. The undervoltage/overvoltage circuits and the power on reset circuitry suppress the gate turn on until the mechanical bounce has ended. The X80010 turns on the gate with a user set slew rate to limit the inrush current and incorporates an electronic circuit breaker set by a sense resistor. After the load is successfully charged, the PWRGD signal is asserted; indicating that the device is ready to power sequence the DC/DC power bricks.
