Automatic Measuring in Standar
消耗积分:5 | 格式:rar | 大小:335 | 2009-01-13
郑成枝
分享资料个
Automatic Measuring in Standard M/PAL using a M/NTSC Video Analyzer UAF or
Video Measurement System VSA
1. Select standard M/PAL. Insert into SAF or SFF Memory Card with testsignals
according to NTC Combination and NTC Composite Signal or create these signals
using SIGNAL EDIT (see also page 3).
2. Insert signals into Vertical Blanking Interval:
3. Change subcarrier frequency in SAF/SFF from M/PAL to 3.579545 MHz acc. to
M/NTSC .
4. You now may measure with the output signal of the SAF or SFF all parameters
siutable to NTCCOMBI.ULC and NTCCOMPO.ULC in the standard M/PAL. But you
should remember that the subcarrier frequency is the one of M/NTSC (the offset of
2511 Hz does not influence the measurement):
评论(0)
发评论
下载排行榜
