ADIN300和ADIN1200 wiki Page
消耗积分:2 | 格式:pdf | 大小:38.33KB | 2021-03-22
刘敏
分享资料个
This version (16 Feb 2021 05:36) was approved by Aaron Paulo Heredia.The Previously approved version (16 Feb 2021 03:08) is available.Diff
ADIN1300 and ADIN1200 Product Wiki Page and Evaluation Documentation
The product pages for the ADIN1300 and ADIN1200 Ethernet PHYs can be found on the link below: https://www.analog.com/en/products/adin1300.html https://www.analog.com/en/products/adin1200.html
Content
1. ADIN1300 and ADIN1200 Circuit & Layout Considerations - This user guide contains recommended PCB layout, proper etches, and selection of hardware components in designing a physical layer circuit using the ADIN1300 and ADIN1200.
2. ADIN1300 and ADIN1200 with Capacitive Coupling - This wiki page contains recommended circuit, and application for a transformerless ADIN1300 and ADIN1200 Physical Layer Circuit.
3. KSZ8081 to ADIN1200 Rollover Report -This document contains a simple rollover report on how to convert the KSZ8081 to ADIN1200 as the Physical Layer Device.
评论(0)
发评论
下载排行榜
