74系列芯片中文资料下载
74LS85.pdf 74LS83A.pdf 74LS75.pdf 74LS74.pdf 74LS73A.pdf 74LS688.pdf 7400.pdf 74LS651.pdf 74LS51.pdf 74LS49.pdf 74LS48.pdf 74LS42.pdf 74LS38.pdf 74LS379.pdf 74LS368A.pdf 74LS367.pdf 74LS365.pdf 74LS352.pdf 74LS32.pdf 74LS30.pdf 74LS283.pdf 74LS28.pdf 74LS279.pdf 74LS27.pdf 74LS258.pdf 74LS257.pdf 74LS256.pdf 74LS253.pdf 74LS245.pdf 74LS244.pdf 74LS21.pdf 74LS20.pdf 74LS195A.pdf 74LS194A.pdf 74LS193.pdf 74LS192.pdf 74LS191.pdf 74LS190.pdf 74LS175.pdf 74LS174.pdf 74LS173.pdf 74LS169.pdf 74LS168.pdf 74LS164.pdf 74LS163A.pdf 74LS162A.pdf 74LS161A.pdf 74LS160A.pdf 74LS158.pdf 74LS157.pdf 74LS156.pdf 74LS155.pdf 74LS153.pdf 74LS151.pdf 74LS14.pdf 74LS139.pdf 74LS138.pdf 74LS136.pdf 74LS125.pdf 74LS114.pdf 74LS113.pdf 74LS112.pdf 74LS11.pdf 74LS109.pdf 74LS10.pdf 74LS09.pdf 74LS08.pdf 74LS05.pdf 74LS04.pdf 74LS03.pdf 74LS02.pdf 74LS00.pdf 74HC943.pdf 74HC942.pdf 74HC86.pdf 74HC85.pdf 74HC76.pdf 74HC75.pdf 74HC74A.pdf 74HC73.pdf 74HC7266.pdf 74HC688.pdf 74HC648.pdf 74HC646.pdf 74HC643.pdf 74HC640.pdf 74HC623.pdf 74HC620.pdf 74HC597.pdf 74HC595.pdf 74HC594.pdf 74HC589.pdf 74HC58.pdf 74HC541.pdf 74HC540.pdf 74HC534.pdf 74HC533.pdf 74HC521.pdf 74HC51.pdf 74HC4543.pdf 74HC4514.pdf 74HC4511.pdf 74HC423A.pdf 74HC42.pdf 74HC4075.pdf 74HC4066.pdf 74HC4060.pdf 74HC4052.pdf 74HC4051.pdf 74HC4050.pdf 74HC4049.pdf 74HC4046.pdf 74HC4040.pdf 74HC4020.pdf 74HC4017.pdf 74HC4016.pdf 74HC393.pdf 74HC374.pdf 74HC373.pdf 74HC368.pdf 74HC367.pdf 74HC366.pdf 74HC365.pdf 74HC356.pdf 74HC354.pdf 74HC34.pdf 74HC32.pdf 74HC30.pdf 74HC299.pdf 74HC283.pdf 74HC280.pdf 74HC273.pdf 74HC27.pdf 74HC266A.pdf 74HC259.pdf 74HC258.pdf 74HC257.pdf 74HC253.pdf 74HC251.pdf 74HC244.pdf 74HC242.pdf 74HC237.pdf 74HC221A.pdf 74HC20.pdf 74HC195.pdf 74HC194.pdf 74HC193.pdf 74HC192.pdf 74HC191.pdf 74HC190.pdf 74HC182.pdf 74HC181.pdf 74HC175.pdf 74HC174.pdf 74HC173.pdf 74HC166.pdf 74HC165.pdf 74HC164.pdf 74HC163.pdf 74HC161.pdf 74HC157.pdf 74HC155.pdf 74HC154.pdf 74HC153.pdf 74HC151.pdf 74HC149.pdf 74HC148.pdf 74HC147.pdf 74HC14.pdf 74HC139.pdf 74HC138.pdf 74HC137.pdf 74HC133.pdf 74HC132.pdf 74HC126.pdf 74HC125.pdf 74HC123A.pdf 74HC113.pdf 74HC112.pdf 74HC11.pdf 74HC109A.pdf 74HC107.pdf 74HC08.pdf 74HC05.pdf 74HC04.pdf 74HC03.pdf 74HC02.pdf 74HC00.pdf 7486.pdf 7485.pdf 7476.pdf 7475.pdf 7474.pdf 7445.pdf 7438.pdf 7432.pdf 7430.pdf 7427.pdf 7426.pdf 7420.pdf 74191.pdf 74180.pdf 74155.pdf 74153.pdf 7414.pdf 74132.pdf 74121.pdf 7411.pdf 7410.pdf 7409.pdf 7408.pdf 7406.pdf 7404.pdf 7403.pdf 7402.pdf 7401.pdf 74LS670.pdf 74LS95B.pdf 74LS90.pdf 74LS86.pdf |
常用74系列功能介绍:
7400 TTL 2输入端四与非门
7401 TTL 集电极开路2输入端四与非门
7402 TTL 2输入端四或非门
7403 TTL 集电极开路2输入端四与非门
7404 TTL 六反相器
7405 TTL 集电极开路六反相器
7406 TTL 集电极开路六反相高压驱动器
7407 TTL 集电极开路六正相高压驱动器
7408 TTL 2输入端四与门
7409 TTL 集电极开路2输入端四与门
7410 TTL 3输入端3与非门
74107 TTL 带清除主从双J-K触发器
74109 TTL 带预置清除正触发双J-K触发器
7411 TTL 3输入端3与门
74112 TTL 带预置清除负触发双J-K触发器
7412 TTL 开路输出3输入端三与非门
74121 TTL 单稳态多谐振荡器
74122 TTL 可再触发单稳态多谐振荡器
74123 TTL 双可再触发单稳态多谐振荡器
74125 TTL 三态输出高有效四总线缓冲门
74126 TTL 三态输出低有效四总线缓冲门
7413 TTL 4输入端双与非施密特触发器
74132 TTL 2输入端四与非施密特触发器
74133 TTL 13输入端与非门
74136 TTL 四异或门
74138 TTL 3-8线译码器/复工器
74139 TTL 双2-4线译码器/复工器
7414 TTL 六反相施密特触发器
74145 TTL BCD—十进制译码/驱动器
7415 TTL 开路输出3输入端三与门
74150 TTL 16选1数据选择/多路开关
74151 TTL 8选1数据选择器
74153 TTL 双4选1数据选择器
74154 TTL 4线—16线译码器
74155 TTL 图腾柱输出译码器/分配器
74156 TTL 开路输出译码器/分配器
74157 TTL 同相输出四2选1数据选择器
74158 TTL 反相输出四2选1数据选择器
7416 TTL 开路输出六反相缓冲/驱动器
74160 TTL 可预置BCD异步清除计数器
74161 TTL 可予制四位二进制异步清除计数器
74162 TTL 可预置BCD同步清除计数器
74163 TTL 可予制四位二进制同步清除计数器
74164 TTL 八位串行入/并行输出移位寄存器
74165 TTL 八位并行入/串行输出移位寄存器
74166 TTL 八位并入/串出移位寄存器
74169 TTL 二进制四位加/减同步计数器
7417 TTL 开路输出六同相缓冲/驱动器
74170 TTL 开路输出4×4寄存器堆
74173 TTL 三态输出四位D型寄存器
74174 TTL 带公共时钟和复位六D触发器
74175 TTL 带公共时钟和复位四D触发器
74180 TTL 9位奇数/偶数发生器/校验器
74181 TTL 算术逻辑单元/函数发生器
74185 TTL 二进制—BCD代码转换器
74190 TTL BCD同步加/减计数器
74191 TTL 二进制同步可逆计数器
74192 TTL 可预置BCD双时钟可逆计数器
74193 TTL 可预置四位二进制双时钟可逆计数器
74194 TTL 四位双向通用移位寄存器
74195 TTL 四位并行通道移位寄存器
74196 TTL 十进制/二-十进制可预置计数锁存器
74197 TTL 二进制可预置锁存器/计数器
7420 TTL 4输入端双与非门
7421 TTL 4输入端双与门
7422 TTL 开路输出4输入端双与非门
74221 TTL 双/单稳态多谐振荡器
74240 TTL 八反相三态缓冲器/线驱动器
74241 TTL 八同相三态缓冲器/线驱动器
74243 TTL 四同相三态总线收发器
74244 TTL 八同相三态缓冲器/线驱动器
74245 TTL 八同相三态总线收发器
74247 TTL BCD—7段15V输出译码/驱动器
74248 TTL BCD—7段译码/升压输出驱动器
74249 TTL BCD—7段译码/开路输出驱动器
74251 TTL 三态输出8选1数据选择器/复工器
74253 TTL 三态输出双4选1数据选择器/复工器
74256 TTL 双四位可寻址锁存器
74257 TTL 三态原码四2选1数据选择器/复工器
74258 TTL 三态反码四2选1数据选择器/复工器
74259 TTL 八位可寻址锁存器/3-8线译码器
7426 TTL 2输入端高压接口四与非门
74260 TTL 5输入端双或非门
74266 TTL 2输入端四异或非门
7427 TTL 3输入端三或非门
74273 TTL 带公共时钟复位八D触发器
74279 TTL 四图腾柱输出S-R锁存器
7428 TTL 2输入端四或非门缓冲器
74283 TTL 4位二进制全加器
74290 TTL 二/五分频十进制计数器
74293 TTL 二/八分频四位二进制计数器
74295 TTL 四位双向通用移位寄存器
74298 TTL 四2输入多路带存贮开关
74299 TTL 三态输出八位通用移位寄存器
7430 TTL 8输入端与非门
7432 TTL 2输入端四或门
74322 TTL 带符号扩展端八位移位寄存器
74323 TTL 三态输出八位双向移位/存贮寄存器
7433 TTL 开路输出2输入端四或非缓冲器
74347 TTL BCD—7段译码器/驱动器
74352 TTL 双4选1数据选择器/复工器
74353 TTL 三态输出双4选1数据选择器/复工器
74365 TTL 门使能输入三态输出六同相线驱动器
74366 TTL 门使能输入三态输出六反相线驱动器
74367 TTL 4/2线使能输入三态六同相线驱动器
74368 TTL 4/2线使能输入三态六反相线驱动器
7437 TTL 开路输出2输入端四与非缓冲器
74373 TTL 三态同相八D锁存器
74374 TTL 三态反相八D锁存器
74375 TTL 4位双稳态锁存器
74377 TTL 单边输出公共使能八D锁存器
74378 TTL 单边输出公共使能六D锁存器
74379 TTL 双边输出公共使能四D锁存器
7438 TTL 开路输出2输入端四与非缓冲器
74380 TTL 多功能八进制寄存器
7439 TTL 开路输出2输入端四与非缓冲器
74390 TTL 双十进制计数器
74393 TTL 双四位二进制计数器
7440 TTL 4输入端双与非缓冲器
7442 TTL BCD—十进制代码转换器
74373 TTL 三态同相八D锁存器
74374 TTL 三态反相八D锁存器
74375 TTL 4位双稳态锁存器
74380 TTL 多功能八进制寄存器
74390 TTL 双十进制计数器
74393 TTL 双四位二进制计数器
7440 TTL 4输入端双与非缓冲器
74447 TTL BCD—7段译码器/驱动器
7445 TTL BCD—十进制代码转换/驱动器
74450 TTL 16:1多路转接复用器多工器
74451 TTL 双8:1多路转接复用器多工器
74453 TTL 四4:1多路转接复用器多工器
7446 TTL BCD—7段低有效译码/驱动器
74460 TTL 十位比较器
74461 TTL 八进制计数器
74465 TTL 三态同相2与使能端八总线缓冲器
74466 TTL 三态反相2与使能八总线缓冲器
74467 TTL 三态同相2使能端八总线缓冲器
74468 TTL 三态反相2使能端八总线缓冲器
74469 TTL 八位双向计数器
7447 TTL BCD—7段高有效译码/驱动器
7448 TTL BCD—7段译码器/内部上拉输出驱动
74490 TTL 双十进制计数器74491 TTL 十位计数器
74498 TTL 八进制移位寄存器
7450 TTL 2-3/2-2输入端双与或非门
74502 TTL 八位逐次逼近寄存器
74503 TTL 八位逐次逼近寄存器
7451 TTL 2-3/2-2输入端双与或非门
74533 TTL 三态反相八D锁存器
74534 TTL 三态反相八D锁存器
7454 TTL 四路输入与或非门
74540 TTL 八位三态反相输出总线缓冲器
7455 TTL 4输入端二路输入与或非门
74563 TTL 八位三态反相输出触发器
74564 TTL 八位三态反相输出D触发器
74573 TTL 八位三态输出触发器
74574 TTL 八位三态输出D触发器
74645 TTL 三态输出八同相总线传送接收器
74670 TTL 三态输出4×4寄存器堆
7473 TTL 带清除负触发双J-K触发器
7474 TTL 带置位复位正触发双D触发器
7476 TTL 带预置清除双J-K触发器
7483 TTL 四位二进制快速进位全加器
7485 TTL 四位数字比较器
7486 TTL 2输入端四异或门
7490 TTL 可二/五分频十进制计数器
7493 TTL 可二/八分频二进制计数器
7495 TTL 四位并行输入\输出移位寄存器
7497 TTL 6位同步二进制乘法器
全部124条评论
