基于EVAL-ADM1272EBZ热插拔控制器的参考设计
消耗积分:2 | 格式:pdf | 大小:1.18MB | 2021-07-13
KANA
分享资料个
说明
  • EVAL-ADM1272EBZ, Evaluation Board for the ADM1272. The board layout provides a clear visual of all the peripheral components and the hot swap power path. The layout also maximizes the ability of the board to dissipate heat for some of the key components on the power path, allowing the evaluation of high current hot swap setups. Two sense resistor slots and four (two on the bottom side) multi package FET slots provide great flexibility and allow a wide range of application setups. Multiple test points allow easy access to all critical points and pins. Six LEDs provide direct visual indication on variations in the board status, such as supply input, output, GPIO1, GPIO2, power good and fault. The kit supports PMBus communication, allowing the user to communicate with the ADM1272
主要特色
  • Input Voltage
    16 to 80 V
  • Output Voltage
    48 V
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
