MAX9945 pdf datasheet (MOS-Inp
消耗积分:5 | 格式:rar | 大小:333 | 2009-02-11
kmno4
分享资料个
The MAX9945 operational amplifier features an excellent combination of low operating power and low input voltage noise. In addition, MOS inputs enable the MAX9945 to feature low input bias currents and low input current noise. The device accepts a wide supply voltage range from 4.75V to 38V and draws a low 400µA quiescent current. The MAX9945 is unity-gain stable and is capable of rail-to-rail output voltage swing.
The MAX9945 is ideal for portable medical and industrial applications that require low noise analog front-ends for performance applications such as photodiode transimpedance and chemical sensor interface circuits.
The MAX9945 is available in both an 8-pin µMAX® and a space-saving, 6-pin TDFN package, and is specified over the automotive operating temperature range (-40°C to +125°C).
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
