系统 |
处理器 |
14nm LGA1151Intel® Core™ i7-6700/i5-6400/i3-6100 CPU |
芯片组 |
Intel® C236 |
内存 |
可装4块288-pin 2133 MHz 双通道 DDR4 SDRAM ECC and 非ECC检测 DIMMs 支持高达 64GB |
显示接口 |
1xVGA(up to 1920x1200@60Hz)
1xDVI-D(up to 2560x1600@60Hz)
1 x HDMI 2.0 (up to 4096x2160@60Hz) |
1 x iDP interface for HDMI, LVDS, VGA, DVI, DP (up to 4096x2304@60Hz) |
I/O接口 |
8 x bit digital I/O (2x5 pin) |
4 x USB 2.0 |
1 x USB 3.0 |
4 x RS-232 (2 x 5 PIN,P=2.0) 2 x RS-422/485 (2 x 5 PIN,P=2.54) |
1 x LPT (2 x 13PIN,P=2.54) |
6 x SATA 6Gb/s |
1 x KB/MS (1 x 6PIN) |
扩展接口 |
1 x Full-size PCIe Mini card slot |
2 x PCI slot |
2 x PCIe x8 slot (Gen3) |
3 x PCIe x4 slot (Gen3) |
以太网接口 |
LAN1 |
Intel® I219LM with Intel® AMT 11.0 support |
LAN2 |
Intel® I210AT PCIe controller |
存储设备 |
硬盘 |
2.5寸480G SSD(默认) |
应用环境 与 机械尺寸 |
工作温度 |
-20°C ~ 60°C |
存储温度 |
-40℃~+80℃ |
相对湿度 |
5%至95% 非冷凝 |
机箱机械尺寸 |
364mm(L)×330mm(W)×198.2mm(H) |
操作系统 |
win8、win10、linux |
