从破坏机理和损伤阈值方面分析了光电探测器的干扰机理。给出了激光干扰概率模型,提出自适应干扰和时域均匀干扰两种干扰模式,对两种不同干扰方式下扫描成像设备的干扰概率进行了理论计算并得出了试验结果,验证了侦察-干扰工作模式的有效性,证明了激光自适应干扰是光电对抗中的首选干扰方式。
关 键 词 光电对抗; 自适应干扰; 干扰效果; 干扰机理
Abstract The interfering mechanism on the photoelectric detector is analyzed in damage mechanism and jamming threshold. The model of laser interfering probability is given. The self-adaptive interference and even time-domain interference are provided and the theoretic probability of two different types of interference on the IR scanning imaging systems is calculated. The effectiveness of surveillance and interference mode is proved in the experimental results. It is also proved that the laser self-adaptive interference is the first choice in different types of optoelectronic countermeasures.
