sv2v:从SystemVerilog到Verilog , sv2v将SystemVerilog (IEEE 1800-2017)转换为Verilog (IEEE 1364-2005), 重点是支持了可合成的语言结构。
其主要目标是创建一个完全免费和开放源码的工具,用于将SystemVerilog转换为Verilog。虽然执行这种转换的方法已经存在,但它们通常要么依赖于商业工具,要么受到范围的限制。
用法
sv2v [OPTIONS] [FILES]
Preprocessing:
-I --incdir=DIR Add directory to include search path
-D --define=NAME[=VALUE] Define a macro for preprocessing
--siloed Lex input files separately, so macros from
earlier files are not defined in later files
--skip-preprocessor Disable preprocessor
Conversion:
-E --exclude=CONV Exclude a particular conversion (always, assert,
interface, or logic)
-v --verbose Retain certain conversion artifacts
-w --write=MODE How to write output; default is 'stdout'; use
'adjacent' to create a .v file next to each input
Other:
--help Display help message
--version Print version information
--numeric-version Print just the version number
