NI offers software options you can use across the entire NI vision hardware portfolio. Configure your system with NI Vision Builder for Automated Inspection, an easy-to-use, stand-alone package for machine vision, or program it using the NI Vision Development Module, a comprehensive library of imaging functions. NI vision software helps you to take advantage of hundreds of image processing algorithms, make decisions based on multiple inspection results, view results through customizable deployment interfaces, and communicate results using I/O and industrial communication processes.
功能
New Detect Texture Defects step. The Detect Texture Defects step can identify defects in a region of interest based on a texture classifier that contains information about the texture.
New Inspect Contours step. The Inspect Contours step can extract a contour from the inspection image, then compare the selected contour with a fitted contour or a template contour to detect contour defects.
New Color Segmentation step. The Color Segmentation step can segment a color image based on a color classifier that contains information about learned color classes.
New LabVIEW API. Use the LabVIEW API to control Vision Builder AI from a LabVIEW application.
See Readme.html for further description of new features
New support for image variables, including local, shared, and network-shared variables.
注册说明
The evaluation period is 30 days. At the end of the evaluation period you must activate a Vision Builder AI license to continue using the product. Note: While Vision Builder AI is in Evaluation mode, all features are available except Migrate Inspection to LabVIEW.
全部3条评论
