不使用光耦反馈的低成本反激式转换器设计
消耗积分:0 | 格式:pdf | 大小:1 MB | 2011-03-28
刘明
分享资料个
  Abstract: This reference design is for a highly efficient, flyback, 12V, Class 3 powered device (PD). The design features the MAX5969B as its controller. The design also uses the MAX5974A, which controls current-mode PWM converters and provides frequency foldback for PoE applications. Using these devices, this reference design is IEEE® 802.3af/at compliant and is a high-performance, compact, and cost efficient solution for a Class 3 PD. The design can also be customized to 12V/2A Class 4 PD.
评论(0)
发评论
下载排行榜
