使用Arduino的自控机器人汽车
消耗积分:2 | 格式:zip | 大小:0.16 MB | 2022-11-16
李勇
分享资料个
一、简介
使用 Arduino 的自控机器人汽车。
这辆机器人汽车使用超声波传感器来检测前方的障碍物,每当它检测到障碍物时,它的超声波传感器就会在左右两个方向上移动,以计算出自由移动的最佳距离。
它的超声波传感器范围高达 150 厘米。
2. 示范
3. 制作这款机器人汽车的步骤
在 Arduino IDE 中导入 Servo.h 和 NewPing.h 库。
// Library
#include         // Include Servo Library
#include       // Include Newping Library
初始化引脚
// L298N Control Pins
const int LeftMotorForward = 4;
const int LeftMotorBackward = 5;
const int RightMotorForward = 6;
const int RightMotorBackward = 7;
const int LEDext = 1;
const int Buzzer = 0;
#define TRIGGER_PIN  A1  // Arduino pin to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     A2  // Arduino pin to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 250 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 250cm.
创建对象和变量
Servo servo_motor;  // Servo's name
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
boolean goesForward = false;
int distance = 50;
编写 Arduino 代码的设置部分
 void setup()
// Set L298N Control Pins as Output
pinMode(RightMotorForward, OUTPUT);
pinMode(LeftMotorForward, OUTPUT);
pinMode(LeftMotorBackward, OUTPUT);
pinMode(RightMotorBackward, OUTPUT);
pinMode(LEDext, OUTPUT);        //set led as output
pinMode(Buzzer, OUTPUT);        //set buzzer as output
servo_motor.attach(9);   // Attachs the servo on pin 9 to servo object.
servo_motor.write(115);   // Set at 115 degrees.
delay(2000);              // Wait for 2s.
distance = readPing();    // Get Ping Distance.
delay(100);               // Wait for 100ms.
编写 Arduino 代码的无效循环部分
void loop()
  int distanceRight = 0;  //Initialize right side distance
  int distanceLeft = 0;   //Initialize left side distance
  delay(50);
  if (distance <= 30)   //If distance of obstacle less than 30 cm from robot
    Stop();   //call stop function to stop the robot
    digitalWrite(LEDext, HIGH);   //Turn led ON
    digitalWrite(Buzzer, HIGH);   //Turn Buzzer ON
    delay(300);   //wait for 300ms
    moveBackward();   //call moveBackward function to move robot in backward direction
    delay(400);   //wait for 400ms
    distanceRight = lookRight();    //call lookRight function to save distance in distanceRight variable
    distanceLeft = lookLeft();    //call lookLeft function to save distance in distanceLeft variable
    if (distanceRight >= distanceLeft)    //If distance of right greater or equall to distance of left
      turnRight();    //call function to turn right robot
      Stop();   //call stop function to stop robot
    else //else
      turnLeft();   //call function to turn left robot
  else    //else
    moveForward();    //call moveForward function to move robot in forward direction
    distance = readPing();    //call readPing function to calculate Distance
制作计算右侧距离的函数
int lookRight()     // lookRight Function for Servo Motor
  servo_motor.write(0);   //make servo position at 0 degree
  delay(500);   //wait for 500ms
  int distance = readPing();    //read distance
  delay(100);   //wait for 100ms
  servo_motor.write(90);    //make servo position 90 degree
  return distance;    //return distance whenever lookRight function is called
制作计算左侧距离的函数
int lookLeft()      // lookLeft Function for Servo Motor
  servo_motor.write(180);   //make servo position at 0 degree
  return distance;    //return distance whenever lookLeft function is called
使功能与超声波传感器保持距离
int readPing()      // readPing Function for Ultrasonic Sensor.
  delay(100);                 // Wait 100ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  int cm = sonar.ping_cm();   //Send ping, get ping distance in centimeters (cm).
  if (cm==0)
    cm=250;
  return cm;    //return distance whenever readPing function is called
制作停止机器人的功能
void Stop()       // Stop Function for Motor Driver.
  digitalWrite(RightMotorForward, LOW);
  digitalWrite(RightMotorBackward, LOW);
  digitalWrite(LeftMotorForward, LOW);
  digitalWrite(LeftMotorBackward, LOW);
使机器人向前移动的功能
void moveForward()    // Move Forward Function for Motor Driver.
    digitalWrite(RightMotorForward, HIGH);
    digitalWrite(LeftMotorForward, HIGH);
    digitalWrite(LEDext, LOW);
    digitalWrite(Buzzer, LOW);
使机器人向后移动的功能
void moveBackward()   // Move Backward Function for Motor Driver.
  digitalWrite(RightMotorBackward, HIGH);
  digitalWrite(LeftMotorBackward, HIGH);
使机器人向右移动的功能
void turnRight()      // Turn Right Function for Motor Driver.
使机器人在左侧方向移动的功能
void turnLeft()       // Turn Left Function for Motor Driver.
将代码上传到您的 Arduino 板。
4. 按照原理图连接所有组件。
评论(0)
发评论
下载排行榜
