蓝牙控制的Arduino机器人
消耗积分:0 | 格式:zip | 大小:0.01 MB | 2023-06-27
14230
分享资料个
代码
#include
SoftwareSerial bt(10,11); // assigning 10 as RX ans 11 as TX
#define motor_left 5
#define motor_right 3
#define motor_right_dir 2
#define motor_left_dir 4
void setup() {
 pinMode(2,OUTPUT);
 pinMode(3,OUTPUT);
 pinMode(4,OUTPUT);
 pinMode(5,OUTPUT);
 while(!Serial){;} // waiting for serial communication to setup
 bt.begin(9600); // beginning the bluetooth connection
void loop() {
 bt.listen(); // listening to the bluetooth
 while(bt.available()) // till we are receiving the input continue in the loop
     char ch = bt.read();  // reading one character at a time
     if(ch=='f'){          // action to be performed if input is 'f'
       digitalWrite(motor_left_dir,HIGH);
       digitalWrite(motor_right_dir,HIGH);
       analogWrite(motor_left,150);
       analogWrite(motor_right,150);
     else if(ch == 'b'){       // action to be performed if input is 'b'
       digitalWrite(motor_left_dir,LOW);
       digitalWrite(motor_right_dir,LOW);
     else if(ch == 'l'){       // action to be performed if input is 'l'
       analogWrite(motor_left,0);
       analogWrite(motor_right,120);
     else if(ch == 'r'){     // action to be performed if input is 'r'
       analogWrite(motor_left,120);
       analogWrite(motor_right,0);
     else if(ch =='s'){  // action to be performed if input is 's'
电路组装
用于蓝牙控制的 Arduino 机器人汽车的电路组件
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
