CM3317,pdf (Color Sensor (RGB Sensor, RGBS))
消耗积分:0 | 格式:pdf | 大小:101 KB | 2011-05-01
dplion
分享资料个
CM3317 Color Sensor (RGB Sensor, RGBS) is a highly integrated design for a RGB light sensing surface mount solution. In a single chip, it incorporates a photodiode for Red/Green/Blue light individual sensing amplifiers, analog/digital circuits, and an I2C protocol interface by the analog CMOS process.
CM3317’s adoption of the Filtron™ technology allows the closest ambient light spectral sensitivity to real human eye responses. Capella RGBS has an excellent temperature compensation capability via an embedded temperature sensor for keeping the output stable under various temperature configurations, and provides temperature information for the system application usage. Its robust refresh rate setting does not need an external RC low pass filter. CM3317's operation voltage ranges from 2.7 V and 5.5 V.
评论(1)
发评论
wangchaohui 2011-07-06
0 回复 举报
很珍稀的資料啊 收起回复
下载排行榜
全部1条评论
