L3G3250A pdf datasheet
消耗积分:0 | 格式:rar | 大小:233 KB | 2011-09-02
dplion
分享资料个
The L3G3250A is a low-power three-axis angular rate sensor.
It includes a sensing element and an IC interface capable of providing the measured angular rate to the external world via three analog outputs.
The sensing element is manufactured using a dedicated micro-machining process developed by STMicroelectronics to produce inertial sensors and actuators on silicon wafers.
The IC interface is manufactured using a CMOS process that allows a high level of integration to design a dedicated circuit which is trimmed to better match the sensing element characteristics.
The L3G3250A is available in a plastic land grid array (LGA) package and can operate within a temperature range from -40 °C to +85 °C.
  • Two selectable full scales (625/2500 dps)
  • Embedded self-test
  • Wide supply voltage range: 2.4 V to 3.6 V
  • Embedded power-down and sleep mode
  • Embedded low-pass filter
  • Integrated high-pass filter reset
  • High shock survivability
  • Extended operating temperature range (-40 °C to 85 °C)
  • ECOPACK® RoHS and “Green” compliant
评论(0)
发评论
下载排行榜
