HV系列代替国外12AV300
消耗积分:0 | 格式:doc | 大小:0.15 MB | 2023-11-02
深圳市俞霖科技开发有限公司
  • 716内容
  • 31w+阅读
  • 78粉丝
0.2~2W, Miniature SIP, Single/Dual Output DC/DC Converters
Features
  • Efficiency up to 88%
  • 1000VDC /3000VDC Isolation
  • MTBF > 2,000,000 Hours
  • Low Cost
  • Input 5, 12, 15 and 24VDC
  • Output 100,110、150、180、200 、250、300、 500、800VDC
±50、±55、 ±75、±90、 ±100、 ±125、±150、 ±250and±400VDC
  • Temperature Performance -40℃~ +85℃
  • UL 94V-0 Package Material
  • Internal SMD Construction
  • Industry Standard Pin out
Block Diagram
ABSOLUTE MAXIMUM RATINGS
Short-Circuit Protection
60 Second
Lead Temperature 1.5mm from case for seconds
300℃
Internal Power Dissipation
450mW
Input Voltage Vin , HV05types
7V
Input Voltage Vin ,HV12 types
15V
Input Voltage Vin ,HV15 types
18V
Input Voltage Vin ,HV 24 types
28V
Model Selection Guide
Model  Number
Input  Voltage
Input Current
Output
Voltage
Output Current
Efficiency
Max Load
No Load
Max Load
VDC
mA (typ)
mA(typ)
VDC
mA(max)
%(typ)
HV05200S-W2
5(4.5~5.5)
67
15
200
1
60
±100
±1
HV12180S-2W
12(10.8~13.2)
200
23
180
10
75
±90
±10
HV12300S-2W
(12SMV300)
12(10.8~13.2)
200
18
300
6
75
±150
±6
HV24200S-2W
24(21.6~26.4)
104
15
200
10
80
±100
±10
Input Specifications
Parameter
Model
Min
Typ
Max
Unit
Input Voltage
5
4.5
5
5.5
VDC
12
10.8
12
13.2
15
13.5
15
16.5
24
21.6
24
26.4
Reverse Polarity Input Current
All Models
0.3
A
Input Filter
Internal Capacitor
Output specifications
Parameter
Conditions
Min
Typ
Max
Unit
Output Voltage Accuracy
±3.0
±5.0
Output Voltage Balance
Dual Output Balanced Loads
±3
±4
Line Regulation
For  Vin Change of 1%
±1.2
±1.5
Load Regulation
Io=20% to 100%
8
15
Ripple﹠Noise(20MHz)
Output
0.5%
1%
V
Ripple﹠Noise(20MHz)
Over Line , Load﹠Temp
2%
V
Over Load
120
Temperature Coefficient
±0.01
±0.02
Output Short Circuit
60 Second
General Specifications
ParameterConditionsMin
Typ
MaxUnit
  A Series
Isolation Voltage Rated60 Seconds1000VDC
Isolation Voltage Test
Flash  Tested  for
1 Second
1000VAC
Isolation Resistance500VDC1000
Isolation Capacitance100KHz,1V60100PF
Switching Frequency 50100120KHz
MTBFMIL-HDBK-217F@25℃,Ground benign2000K Hours
Environmental Specifications
Parameter
Conditions
Min
Typ.
Max
Unit
Operating Temperature
Ambient
-40
+85
Case
-40
+90
Storage Temperature
-40
+125
Humidity
95
Cooling
Free-Air convection
MECHANICAL DIMENSIONS            TUBE OUTLINE DIMENSIONS
评论(0)
发评论
下载排行榜
