ISO 6722-1-2011 道路--60V和600V芯--第1部分:尺寸、方法及要求
消耗积分:0 | 格式:pdf | 大小:0.08 MB | 2023-11-02
越联仪器
  • 168内容
  • 6w阅读
  • 39粉丝
1 Scope
This part of ISO 6722 specifies the dimensions, test methods, and reauirements for single-core 60 V cables intended for use in road vehicle applications where the nominal system voltage is ≤(60 V d.c. or 25 V a.c.). also specifies additional test methods and/or reauirements for 600 V cables intended for use in road vehicle applications where the nominal svstem voltaae is areater than >(60 V d.c. or 25 V a.c.) to <(600 V d.c. or600 V a.c.). It also applies to individual cores in multi-core cables.
This part of ISO 6722 specifies requirements for copper conductor cables
2 Normativereferences
The followina referenced documents are indispensable for the application of this document. For datec references. only the edition cited applies. For undated references. the latest edition of the referenced document (including anyamendments)applies.
IsO 1817,Rubber vulcanized or thermoplastic -Determination of the effect of liquids
ISO 6931-1.Stainless steels for springs-Part 1:Wire
EC 60811 2-1. Common test methods for insulatina and sheathina materials of electric and optical cables - Part 2-1: Methods specific to elastomeric compounds-Ozone resistance, hot set and mineral oil immersion tests
ASTM B1, Standard Specification for Hard Drawn Copper Wire
ASTM B3. Standard Specification for Soft or Annealed Copper Wire
ASTM B33.Standard Specification for Tin Coated Soft or Annealed Copper Wire for Electrical Purposes
ASTM B298, Standard Specification for Silver Coated Soft or Annealed Copper Wire
ASTM B355.Standard Specification for Nickel Coated Soft or Annealed Copper Wire
EN 13602,Copper and copper alloys- Drawn, round copper wire for the manufacture of electrical conductors
评论(0)
发评论
下载排行榜
