一种DS/SS信号盲同步算法
消耗积分:3 | 格式:rar | 大小:209 | 2009-05-10
刘埃生
分享资料个
提出了一种DS/SS信号盲同步算法,在此基础上利用特征分析法可解决相位不确定性的缺陷。该算法简单有效、计算量小,利于硬件实时处理。理论分析及计算机仿真结果表明,该算法在低信噪比条件下可实现DS/SS信号的盲同步及PN码序列的精确估计。
In the lower Signal to Noise (S/N) ratio Direct Sequence Spread Spectrum (DS/SS) signals, the estimated Pseudo-Noise (PN) sequence has a problem of phase indetermination in the method based on eignanalysis techniques. In this paper, we propose a simple and valid approach to blind synchronization of DS/SS signals. The problem above can be resolved by the blind synchronization algorithm. The theoretic analysis and experimental results show that the approach can work well on the lower S/N ratio input signals.
评论(0)
发评论
下载排行榜
