The LTC3546 is a dual output current mode buck regulatorwith fl exible output current partitioning. Beyondthe advantages normally associated with dual outputregulators (reduced size, cost, EMI and part count, withimproved effi ciency), the LTC3546’s outputs can bepartitioned for either 3A and 1A outputs, or two 2A outputs.This increases its application range and simplifi esmultiple supply rail designs. A confi gurable Burst Mode®clamp for each output sets the current transition levelbetween Burst Mode operation and forced continuousconduction mode to optimize effi ciency over the entireoutput range. An adjustable switching frequency up to4MHz and internal power MOSFET switches allow forsmall and compact footprints.
