The LTC®3610 is a high power monolithic synchronousstep-down DC/DC regulator that can deliver up to 12Aof continuous output current from a 4V to 24V (28Vmaximum) input supply. It is a member of a high currentmonolithic regulator family (see Table 1) that featuresintegrated low RDS(ON) N-channel top and bottomMOSFETs. This results in a high effi ciency and highpower density solution with few external components.This regulator family uses a constant on-time valleycurrent mode architecture that is capable of operatingat very low duty cycles at high frequency and with veryfast transient response. All are available in low profi le(0.9mm max) QFN packages.
