三降压稳压器功能的1-Wire动态可编程输出电压
消耗积分:0 | 格式:pdf | 大小:99 KB | 2012-01-13
分享资料个
The LTC®3569 is a compact power solution for handhelddevices. Its tiny 3mm × 3mm QFN package includesthree buck regulators with individually programmableoutput voltages. One regulator supports load currentsup to 1200mA, while the other two support currents to600mA. Two regulators can be paralleled for increasedload capability. Each current-mode regulator is internallycompensated with excellent load and line regulation. Acomplete 2- or 3-output solution requires a minimumof external passive components.
评论(0)
发评论
下载排行榜
