CD4044.pdf
消耗积分:5 | 格式:rar | 大小:122 | 2008-04-02
分享资料个
The CD4043BC are quad cross-couple 3-STATE CMOS
NOR latches, and the CD4044BC are quad cross-couple 3-
STATE CMOS NAND latches. Each latch has a separate Q
output and individual SET and RESET inputs. There is a
common 3-STATE ENABLE input for all four latches. A
logic “1” on the ENABLE input connects the latch states to
the Q outputs. A logic “0” on the ENABLE input disconnects
the latch states from the Q outputs resulting in an
open circuit condition on the Q output. The 3-STATE feature
allows common bussing of the outputs.
Features
 Wide supply voltage range: 3V to 15V
 Low power: 100 nW (typ.)
 High noise immunity: 0.45 VDD (typ.)
 Separate SET and RESET inputs for each latch
 NOR and NAND configuration
 3-STATE output with common output enable
Applications
• Multiple bus storage
• Strobed register
• Four bits of independent storage with output enable
• General digital logic
评论(0)
发评论
下载排行榜
