MAX7030数据手册
消耗积分:0 | 格式:pdf | 大小:221 KB | 2012-07-11
分享资料个
The MAX7030 crystal-based, fractional-N transceiver isdesigned to transmit and receive ASK/OOK data at factory-preset carrier frequencies of 315MHz or433.92MHz with data rates up to 33kbps (Manchesterencoded) or 66kbps (NRZ encoded). This device generatesa typical output power of +10dBm into a 50Ωload and exhibits typical sensitivity of -114dBm. TheMAX7030 features separate transmit and receive pins(PAOUT and LNAIN) and provides an internal RF switchthat can be used to connect the transmit and receivepins to a common antenna.
评论(0)
发评论
下载排行榜
