AD9128是集成了JESD204A串行接口的双通道、16 BIT、1.25GSPS信号处理数模转换器。The AD9128 is a dual, 16-bit, high dynamic range, digital-to-analog converter (DAC) that provides a sample rate of 1.25 GSPS, permitting a multi-carrier generation up to the Nyquist frequency. The AD9128 includes features optimized for direct conversion transmit applications, including complex digital modulation, and gain and offset compensation. The DAC outputs can interface seamlessly with Analog Devices
