小型荧光灯输出光强度变化的补偿技术介绍
消耗积分:3 | 格式:rar | 大小:38 | 2009-05-31
分享资料个
This application note describes the techniques that can be used
to compensate for the natural variation in output intensity of
miniature fluorescent bulbs. The output intensity for any 20nm
bandwidth can vary by as much as +50% from device to device.
A similar figure to LED output intensity tolerance. The major
factors, which cause this variation, are differences in the
phosphor coating from device to device and tolerances of the
anode and cathode geometries. External influences such as
ambient temperature will affect the output intensity. Before
discussing correction schemes the typical distribution of output
intensities is shown for a long wavelength ultra-violet miniature
fluorescent device. Similar distributions are obtained for other
spectral devices. The output intensities at 366nm of 50 lamps
were measured. The distribution is shown below.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
