The HFA1212 Dual Video Buffer can be used to implement differential line drivers and receivers with a minimum of external components (see Figure 2). Common mode rejection is set by the internal matched thin film resistors which are pin strapped to set the various closed loop gains that are required. VIN is terminated into 75Ω and drives both amplifiers in U1. U1A has a gain of -1 while U1B has a gain of +1. These amplifiers create a differential signal with a gain of 2. Series 75Ω resistors provide impedance matching to the transmission line.
