The MAX2900–MAX2904 complete single-chip 200mWtransmitters are designed for use in the 868MHz/915MHz frequency bands. The MAX2900/MAX2901/
MAX2902 are compliant with the FCC CFR47 part 15.247902MHz to 928MHz ISM-band specifications. MAX2903/MAX2904 are compliant with the ETSI EN330-220 specificationfor the European 868MHz ISM band.
