基于FPGA 的(3,6)LDPC 码并行译码器设计与实现
消耗积分:5 | 格式:rar | 大小:214 | 2009-06-06
分享资料个
本文基于Altera的FPGA(StatixⅡ-EP2S30F484C3)架构,实现了码率为1/2,帧长为1008bits的规则(3,6)LDPC码译码器。所采用的最小-和算法相对于传统的和-积算法在不损失译码性能的前提下,降低了硬件实现的复杂度,设计的并行结构有效地解决了串行结构所带来译码延时过大的问题,最大译码速率可达到60Mbit/s。为LDPC码的实际应用奠定了良好的基础。
关键词:LDPC码;校验矩阵;最小和算法;FPGA
Design and Implementation of Parallel Architectures Decoder for(3,6)LDPC Codes Based on FPGA ZHONG Yong-xin, DU Xing-min (The Engineering Institute,Air Force Engineering University,Xi’an 710038,China) Abstract:In this paper,a decoder for (3,6) regular LDPC codes with code rate of 1/2 and block length of 1008 bits has been implemented based on FPGA(StatixⅡ-EP2S30F484C3) of Altera. In compare with traditional sum-product algorithm,min-sum algorithm has close performance and reduces the complication of hardware.Parallel architectures solves the problem of long time delay in serial architectures effectively and can achieve a decoding rate of 50Mbps.It lays a good foundation for application of LDPC codes.
Key words:LDPC codes;Parity check matrix;Min-sum algorithm;FPGA
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
