AD9106 TxDAC和波形发生器高性能四通道DAC
消耗积分:0 | 格式:pdf | 大小:1.36 MB | 2012-12-14
分享资料个
The AD9106 TxDAC® and waveform generator is a high performance quad DAC integrating on-chip pattern memory for complex waveform generation with a direct digital synthesizer (DDS). The DDS is a 12-bit output, up to 180 MHz master clock sinewave generator with a 24-bit tuning word allowing 10.8 Hz/LSB frequency resolution. The DDS has a single frequency output for all four DACs and independent programmable phase shift outputs for each of the four DACs.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
