测氧传感器单参数精确控制碳势
消耗积分:3 | 格式:rar | 大小:147 | 2009-06-25
分享资料个
针对气体渗碳零件质量不稳定问题,使用测氧传感器对渗碳过程进行碳势控制。结果
表明:单参数控制碳势波动大的主要原因是炉气中的CO 含量不恒定。根据渗碳设备、工艺等具体情况,可采用单一渗剂,配制混合渗剂,稀释剂和富化剂按比例同步增减,以及用甲醇作稀释剂,醋酸乙脂作富化剂等4 种处理。
关键词:碳势;测氧传感器;渗碳;氧电势;控制
Abstract :Carbon tendency cont rolled by single2factor method was unstable in theory because the amount of CO was unconstant . According to carburizing devices and technologies of factories , authors solved these problems by using single penet rant ,fixing different penet rant s ,increasing or decreasing the amount s of dilu2 ent s and enrich agent s in proportion and synchronization ,and using alcohol as diluent and acetic ether as en2
rich agent s. After these measures had been taken ,the qualities of accessories had been greatly improved.
Key words :Carbon tendency ;Oxygen sensor ; Gas carburizing ;Oxygen potential ;Cont rol
评论(0)
发评论
下载排行榜
