NCN5120 is a receiver−transmitter IC suitable for use in KNX twisted pair networks (KNX TP1−256)。 It supports the connection of actuators, sensors, microcontrollers, switches or other applications in a building network. NCN5120 handles the transmission and reception of data on the bus. It generates from the unregulated bus voltage stabilized voltages for its own power needs as well as to power external devices, for example, a microcontroller. NCN5120 assures safe coupling to and decoupling from the bus. Bus monitoring warns the external microcontroller for loss of power so that critical data can be stored in time.
