汽车油温油位传感器
Brief Product Description tacho-generator or tachometer adapter1.can show the oil mass in tank.2. warning you can pour oil into a tank.3.when the oil use out,the float ball will down,on the other hand will up. The rotate speed gauge, sensor and protector is matched with the p
Detailed Product Description tacho-generator or tachometer adapter1.can show the oil mass in tank.2. warning you can pour oil into a tank.3.when the oil use out,the float ball will down,on the other hand will up.The rotate speed gauge, sensor and protector is matched with the products in ZheJiang, China.OIL LEVEL SENSORLeveraging upon our streamlined facilities, our fuel sender units are high in quality and in performance. These are offered at industry leading prices and require minimum maintenance. Widely identified by preciseness, accuracy, functionality and reliability, these are safe in use.
