NE5532 芯片资料
FEATURES
• Equivalent Input Noise Voltage: 5 nV/√Hz Typ at 1 kHz
• Unity-Gain Bandwidth: 10 MHz Typ
• Common-Mode Rejection Ratio: 100 dB Typ
• High DC Voltage Gain: 100 V/mV Typ
• Peak-to-Peak Output Voltage Swing 26 V Typ With VCC± = ±15 V and RL = 600 Ω
• High Slew Rate: 9 V/µs Typ
DESCRIPTION/ORDERING INFORMATION NE5532, NE5532A SA5532, SA5532A SLOS075I–NOVEMBER 1979–REVISED APRIL 2009 DUAL LOW-NOISE OPERATIONAL AMPLIFIERS • Equivalent Input Noise Voltage: 5 nV/√Hz Typ at 1 kHz • Unity-Gain Bandwidth: 10 MHz Typ • Common-Mode Rejection Ratio: 100 dB Typ • High DC Voltage Gain: 100 V/mV Typ • Peak-to-Peak Output Voltage Swing 26 V Typ With VCC± = ±15 V and RL = 600 Ω • High Slew Rate: 9 V/µs Typ The NE5532, NE5532A, SA5532, and SA5532A are high-performance operational amplifiers combining excellent dc and ac characteristics. They feature very low noise, high output-drive capability, high unity-gain and maximum-output-swing bandwidths, low distortion, high slew rate, input-protection diodes, and output short-circuit protection. These operational amplifiers are compensated internally for unity-gain operation. These devices have specified maximum limits for equivalent input noise voltage.
