提出一种基于振动敲击来检测软质物体硬度的方法。它利用PVDF 压力薄膜传感器, 检测振动源施加在软质物体上的动态压力及弹性形变, 通过提取波形的特征量及对特征量的主成分分析, 得到了基于特征量的线性组合的硬度表达式。 关键词 硬度检测 主成分分析 PVDF 压电薄膜传感器 Abstract Th is paper p resent s a new method fo r measuring soft material st iffness, based on act ive vibrat ion on it. PVDF senso r is app lied to measure the p ressure and st rain wh ile vibrat ion head get s into and leaves off the soft material. A fter p ick ing up the characterist ic parameters from the senso r output signalwave, p rincipal component analysis is perfo rmed to find the facto rs affect ing the st iffness. A s a result, a linear exp ression can be used to compare the st iffness of soft material. Key words St iffness measurement P rincipal component analysis PVDF senso r
