Comprehensive static timing analysis involves analysis of register-to-register, I/O, and asynchronous resetpaths. Timing analysis with the TimeQuest Timing Analyzer uses data required times, data arrival times,and clock arrival times to verify circuit performance and detect possible timing violations.The TimeQuest analyzer determines the timing relationships that must be met for the design to correctlyfunction, andchecks arrival times against requiredtimes to verify timing. This
chapter is anoverview of the concepts you need to know to analyze your designs with the TimeQuest analyzer。
