The HS0038A2. – series are miniaturized receivers for infrared remote control systems。PIN diode and preamplifier are assembled on lead frame, the epoxy package is designed as IR filter。The demodulated output signal can directly be decoded by a microprocessor。 HS0038A2. is the standard IR remote control receiver series,supporting all major transmission codes。
