【合泰】HT7660 CMOS电压转换器
消耗积分:0 | 格式:pdf | 大小:100KB | 2014-09-05
孔令双
分享资料个
HT7660 is a monolithic CMOS switched-capacitor volt-
age converter. HT7660 is designed to complete a volt-
age conversion from positive to negative. The only
required external components are two low cost electro-
lytic capacitors.
lytic capacitors.
lytic capacitors.
lytic capacitors.
lytic capacitors.
lytic capacitors.
lytic capacitors.
lytic capacitors.
HT7660 is a monolithic CMOS switched-cappacitor voltage converter.HT7660 is designed to complete a voltage conversion from positive to negative.The only required external components are two low cost electrolytic capacitors.
评论(0)
发评论
下载排行榜
