PT2313L 音效处理芯片资料
消耗积分:2 | 格式:pdf | 大小:361KB | 2014-10-29
唐鹏春
分享资料个
PT2313L is a four-channel digital control audio processor utilizing CMOS Technology。 Volume, Bass, Balance, Front/Rear Fader Processor, Selectable Input Gain are incorporated into a single chip having the highest performance and reliability with the least external components。 All functions are programmable using the I2C Bus。PT2313L is housed in 20-pin or 28-pin DIP/SOP Package。The 28-pin version provides additional Two Band Tone Control and Loudness Function and is pin-to-pin compatible with TDA7313。 Pin assignments and application circuits are optimized for easy PCB layout and cost saving advantages。
评论(0)
发评论
下载排行榜
