CCD摄像机标定的研究
消耗积分:5 | 格式:rar | 大小:339 | 2009-08-05
吴湛
分享资料个
在计算机视觉中,二维计算机坐标和三维物体空间坐标的关系可通过摄像机模型来
建立。模型中的参数包括:摄像机几何、光学特性参数(内参数)及摄像机空间位置参数(外参数)。摄像机的标定就是要确定这些参数。本文分析了三维空间点投影在像平面的像点产生畸变的原因:在大视场摄像机镜头各向同性,而且物像空间媒质均匀的情况下,像素单位元面积产生的变化引起像点畸变,并在实际图像坐标到计算机图像(帧存)坐标标定过程中推导出CCD 传感器单元x 方向的比例系数x N 的表达式,并进行了实验测量分析,取得的结果对提高标定精度具有意义。
关键词: 计算机视觉,三维重建,摄像机模型,摄像机标定,畸变
Abstract: With computer visual technology, the relationship between 2-dimensional computer
coordinate and 3-dimensional space coordinate system is built by camera model. Model
parameters include camera geometrical and optical (inside parameters) and space camera
positional parameters (outer parameters). Camera calibration aims at getting these. The paper
produces that the essence of distortion produced by image spot on the image plane projected from 3-dimensional space dot is due to distortion of pixel unit area. And deduce expression of scale coefficient x N along axe x of CCD sensor unit during calibration from physical image coordinate system to computer frame system.
Key words: Computer visual,3-dimensional reconstruction,camera model,camera
calibration,distortion
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
