These hex buffers are monolithic complementary MOS
(CMOS) integrated circuits. The N- and P-channel enhancement
mode transistors provide a symmetrical circuit with
output swings essentially equal to the supply voltage. This
results in high noise immunity over a wide supply voltage
range. No DC power other than that caused by leakage current
is consumed during static conditions. All inputs are protected
against static discharge. These gates may be used
as hex buffers, CMOS to DTL or TTL interface or as CMOS
current drivers. Conversion ranges are from 3V to 15V providing
VCC s VDD.
