The CD4010C hex buffers are monolithic complementary
MOS (CMOS) integrated circuits. The N- and P-channel
enhancement mode transistors provide a symmetrical circuit
with output swings essentially equal to the supply voltage.
This results in high noise immunity over a wide supply
voltage range. No DC power other than that caused by
leakage current is consumed during static conditions. All
inputs are protected against static discharge. These gates
may be used as hex buffers, CMOS to DTL or TTL interface
or as CMOS current drivers. Conversion ranges are
from 3V to 15V providing VCC £ VDD.
