4511 CMOS BCD-7段锁存、译码、LED驱动
消耗积分:5 | 格式:rar | 大小:65 | 2009-08-08
分享资料个
The CD4511BC BCD-to-seven segment latch/decoder/
driver is constructed with complementary MOS (CMOS)
enhancement mode devices and NPN bipolar output drivers
in a single monolithic structure. The circuit provides the
functions of a 4-bit storage latch, an 8421 BCD-to-seven
segment decoder, and an output drive capability. Lamp test
(LT), blanking (BI), and latch enable (LE) inputs are used to
test the display, to turn-off or pulse modulate the brightness
of the display, and to store a BCD code, respectively. It can
be used with seven-segment light emitting diodes (LED),
incandescent, fluorescent, gas discharge, or liquid crystal
readouts either directly or indirectly.
Applications include instrument (e.g., counter, DVM, etc.)
display driver, computer/calculator display driver, cockpit
display driver, and various clock, watch, and timer uses.
评论(1)
发评论
2011-06-30
0 回复 举报
很好 收起回复
下载排行榜
全部1条评论
