ADA4850-1/ADA4850-2,pdf datash
消耗积分:3 | 格式:rar | 大小:962 | 2009-08-31
赵辉
分享资料个
The ADA4850-1/ADA4850-21 are low price, high speed, voltage feedbacks rail-to-rail output op amps with ultralow power-
down. Despite their low price, the ADA4850-1/ADA4850-2
provide excellent overall performance and versatility. The
175 MHz, −3 dB bandwidth and 220 V/μs slew rate make these
amplifiers well-suited for many general-purpose, high speed
applications. The ADA4850-1/ADA4850-2 are designed to operate at supply voltages as low as 2.7 V and up to 6 V at 2.4 mA of supply current per amplifier. In power-down mode, the supply current is less than 150 nA, ideal for battery-powered applications.
The ADA4850 family provides users with a true single-supply
capability, allowing input signals to extend 200 mV below the
negative rail and to within 2.2 V of the positive rail. The output of the amplifier can swing within 80 mV of either supply rail.
With its combination of low price, excellent differential gain (0.12%), differential phase (0.09°), and 0.1 dB flatness out to 14 MHz, these amplifiers are ideal for video applications.
The ADA4850-1/ADA4850-2 are designed to work in the
extended temperature range of −40°C to +125°C.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
