AD8044,pdf datasheet (Rail-to-
消耗积分:5 | 格式:rar | 大小:741 | 2009-09-02
分享资料个
The capacitive load drive of the AD8044 can be increased by
adding a low valued resistor in series with the load. Figure 35
shows the effects of a series resistor on capacitive drive for varying
voltage gains. As the closed-loop gain is increased, the larger
phase margin allows for larger capacitive loads with less overshoot.
Adding a series resistor with lower closed-loop gains
accomplishes this same effect. For large capacitive loads, the
frequency response of the amplifier will be dominated by the
roll-off of the series resistor and capacitive load.
评论(0)
发评论
下载排行榜
