ADL5571,pdf datasheet (WiMAX P
消耗积分:2 | 格式:rar | 大小:556 | 2009-09-03
张亮
分享资料个
The ADL5571 is a high linearity 2.5 GHz to 2.7 GHz power amplifier designed for WiMAX mobile terminals and CPEs using TDD operation at a duty cycle of 50% or lower. With a gain of 29 dB and an output compression point of 31 dBm, it can operate at an output power level up to 27 dBm while maintaining an EVM of ≤3% with a supply voltage of 5 V. PAE is 21% at POUT = 25 dBm with a 3.3 V supply voltage.
评论(0)
发评论
下载排行榜
