AD7801 pdf datasheet (Voltage Output 8-Bit DAC)
消耗积分:3 | 格式:rar | 大小:517 | 2009-09-17
分享资料个
The AD7801 is a single, 8-bit, voltage out DAC that operates
from a single +2.7 V to +5.5 V supply. Its on-chip precision output
buffer allows the DAC output to swing rail to rail. The AD7801
has a parallel microprocessor and DSP compatible interface with
high speed registers and double buffered interface logic. Data is
loaded to the input register on the rising edge of CS or WR.
评论(0)
发评论
下载排行榜
