AD1954,pdf datasheet (12-Bit M
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-28
370217
分享资料个
The DAC121S101 is a full-featured, general purpose 12-bit
voltage-output digital-to-analog converter (DAC) that can operate
from a single +2.7 V to 5.5 V supply and consumes just
177 μA of current at 3.6 V. The on-chip output amplifier allows
rail-to-rail output swing and the three wire serial interface operates
at clock rates up to 20 MHz over the specified supply
voltage range and is compatible with standard SPI™, QSPI,
MICROWIRE and DSP interfaces.
评论(0)
发评论
下载排行榜
