LP3983,pdf datasheet (Regulato
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-05
微风挽雨
分享资料个
The LP3983 is a fixed voltage low current regulator.
The LP3983 is ideally suited to standby type applications in
battery powered equipment, it allows the lifetime of the battery
to be maximized. The device can be controlled via an
Enable(disable) control and can thus be used by the system
to further extend the battery lifetime by reducing the power
consumption to virtually zero.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
