LMC6035/LMC6036,pdf datasheet
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-08
分享资料个
The LMC6035/6 is an economical, low voltage op amp capable
of rail-to-rail output swing into loads of 600Ω.
LMC6035 is available in a chip sized package (8-Bump
micro SMD) using National’s micro SMD package technology.
Both allow for single supply operation and are guaranteed
for 2.7V, 3V, 5V and 15V supply voltage. The 2.7 supply
voltage corresponds to the End-of-Life voltage (0.9V/cell) for
three NiCd or NiMH batteries in series, making the
LMC6035/6 well suited for portable and rechargeable systems.
It also features a well behaved decrease in its specifications
at supply voltages below its guaranteed 2.7V operation.
This provides a “comfort zone” for adequate
operation at voltages significantly below 2.7V. Its ultra low
input currents (IIN) makes it well suited for low power active
filter application, because it allows the use of higher resistor
values and lower capacitor values. In addition, the drive
capability of the LMC6035/6 gives these op amps a broad
range of applications for low voltage systems.
评论(0)
发评论
下载排行榜
