LME49830pdf datasheet (Mono H
消耗积分:5 | 格式:rar | 大小:550 | 2009-10-08
张国厚
分享资料个
The LME49830 is a high fidelity audio power amplifier input
stage designed for demanding consumer and pro-audio applications.
Amplifier output power may be scaled by changing
the supply voltage and number of output devices. The
LME49830 is capable of driving an output stage in excess of
300 W single-ended into an 8Ω load in the presence of 10%
high line headroom and 20% supply regulation.
The LME49830 includes internal thermal shut down circuitry
that activates when the LME49830 die temperature exceeds
150°C. The LME49830 has a mute function that mutes the
input drive signal and forces the amplifier output to a quiescent
state.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
